Dissident Philosophy Forum
welcome to the new culture
HomeRegisterLog in
Share |
 Bible Codes
Is this the Hand of God or Man or Both?
God
0%
 0% [ 0 ]
Man
20%
 20% [ 1 ]
or Both
80%
 80% [ 4 ]
Total Votes : 5
AuthorMessage
Guest
Guest
PostSubject: Bible Codes   Sun Jun 06, 2010 3:54 am
A while back, my Father in Heaven must have given me the knowledge to see something in a text i knew very little about: And i found a set of hidden codes...
I am going t exptrapolate on this mathematical codex, and show that it is indeed one of something very important. This section is about math... Once i am able to finalize a total and accurate statstical analysis of the entire work, i will hope the mods will give this a chance... let's hope eh?
A Dr. Vernon Jenkins found the following facts… before we continue, we must have a look at the Greek Mathematics gematria, and the Chaldean numerical values are:
Alpha = 1
Beta = 2
Gamma = 3
Delta = 4
Epsilon = 6
Digamma = 7
Zeta = 8
Theta = 9
Iota = 10
Kappa = 20
Lambda = 30
Mu = 40
Nu = 50
Xi = 60
Omicron = 70
Pi = 80
Koppa = 90
Rho = 100
Sigma = 200
Tau = 300
Upsilon = 400
Phi = 500
Chi = 600
Psi = 700
Omega = 800
There are [27] Greek letters in total… 22 Hebrew letters in total… Note that 27 + 22 = 7 x 7… keep this in mind…
The idea that the ancient pages of the Kabala, is that it holds a hidden subtext of codes in numbers. This is not a myth, it is actually very much true.
Do not mistake these for the rather poor BBC 4 programmed a yonder of years back, whereas Dr. Eliyahu Rips claimed he had discovered empirical evidence of Bible code phenomena. He used a high-powered computer to [randomly] search for crossword like paragraphs speaking about events that had already happened, and events still to come to pass.
I wasn't moved by his finds. I found his contribution actually a bit shaming for the Bible mathematical community. However, he is a fantastic mathematician, well-renown actually, and he statistically put one of his codes down as 60,000 to 1.
But mathematicians came forward and found him to be incorrect, with a real statistical analysis of only 1 n 2. However, this should not deter the reader, as codes really do exist within the Bible, as i am going to show you.
Dr. Ivan Nikolayevich Panin, a scholar and famous agnostic, born in Russia found a most compelling and spine chilling set of codes... actually, hundreds of them. They where so intricate, the only explanation was intentional design... but why? It turns out that the codes where so complex, called 'the seven phenomena', no scholar or mathematician could really answer why anyone would go to such a lengthly way. The statistics of his finds go into the quadrillions to 1! [You can find his work on the internet - there are plenty of threads].
Another Dr. i wish to speak about today, and before moving onto my own personal find, is a Dr. Vernon Jenkins - he too has his own web page. He simply took the next step and applied geometric patterns into the text, and came up with some extraordinary results. He was able to obtain his calculations from an ancient Hebrew and Chaldean discipline called, 'Theomatics.' By applying each letter of the Hebrew (and) Greek alphabet with their own gematria values, he was able to devise ''whole'' answers. It turns out that these values also held quite a lot in store.
The most interesting find of his, was found in Genesis 1:1. He obtained the following values from using this system: 296-407-395-401-86-203-913.
He found the following facts (I’m mentioning just an iota of what he found) >
the entire system came to a value of 2701.
The entire system is also 37 x 73 (reflective symmetry)
The numbers 37 and 73 are the 12th and 21st primes (reflective system)
The number 2701 is the 703rd triangular number (similarities, almost an anagram) - 703 is also the calculation of 'and the earth' leaving a value of 666 + 666 + 666
This is just a pinch of what he found - you should really go to his site
His second work investigated the first paragraph of John 1:1, which is almost symmetrical in literature. He also found some rather remarkable mathematical results
the word, ''Word'' came to a value of 373... This mirrors the 37 and 73 phenomena
the entire passage valued 3627... Which is 39 x 93 (reflective symmetry)
In fact, the entire thing could be used as a plinth to support the triangular basis of 2701
All coincidence? Perhaps, but he recently put statistical averages to this and found it was highly unlikely
Now, what stood out for me, was that seven was predominant in the first sentence. There are accordingly 7 words. There are 28 letters (Hebrew letters) which is of course 7 x 4. This was indicating something, i thought.
You just need to look at the entire Bible to understand that 7 was the holy number... God rested on the 7th day. Jesus was the 77th generation from Abraham. The 7 churches. The 7 Angels. The 7 plagues. The 7 spirits. The 7 woes... ECT. ECT.
As it turned out, the three nouns 'God', 'Heaven' and 'Earth' added to 777... A triplet... remember this.
So, i decided to investigate the gematria. What ''popped'' out at me, was the numbers 37, 7 and 39. The difference between the number 7 however, is that it was encoded in a differential fasion to both the findings of the 37 and 39 phenomena. So, i treated it differently by doing the following sums...
37 x 7 = 259
39 x 7 = 273
what of these numbers - your probably wondering? Well, if you multiply the two together, they obtain a very similar picture to adding the three nouns together, giving an answer of 70707! But this was only the edge of the blade. It turns out that the joining of 37x7 multiplications with 39x7 multiplications unraveled a host of continuous calculations, that 'may' go into infinity... though, I could be wrong…
Here are the extra calculations I found… But first, I call numbers which have a pattern of (let’s hypothetically say),70707 as ‘’Island Effects’’, and are calculations that are very rare. In short, I will call the Island Effect simply (IE).
37 x 273 = 10101 Palindrome/IE
39 x 259 = 10101 Palindrome/IE
37 x 7 = 259 x 39 x 39 = 393939
37 x 7 = 259 x 93 x 93 = 939393
39 x 7 = 273 x 37 x 37 = 373737
39 x 7 = 273 x 73 x 73 = 737373
And…
We now need to see the importance of two specific numbers… those being 13 and 11… numerically, the Bible finds these numbers highly important, as when Judas Iscariot hung himself, the 12 disciples became ‘’The Eleven,’’ and Jesus was the 13th… the Master. Also to highlight the importance of 11, just remember that there are 22 Hebrew letters, which is of course 11^2. Here I would like to add that 13 cannot be a number of wrath… but holiness
So, let us continue…
77 x 37 x 13 = 37037
77 x 73 x 13 = 73073
77 x 39 x 13 = 39039
77 x 93 x 13 = 93093
77 x 7 x 13 = 7007
7007 x 39 = 273273
7007 x 37 = 259259
Now consider the following mathematics…
2701 + 1072 (mirrored symmetry)= 3773…
3773 is also an anagram of 37 x 73 totaling the value of 2701… (This was Dr. Vernon’s discovery)… but I found a special harmony, crystallizing a supersymmetry and palindrome > totally indicating seven phenomena…
3773(37 x 13 x 39)= 70777707
Right, so i make it that the possibility of chance to be 1 in 108,775,477,775.
My English Bible Code Analysis
A=1
B=2
C=3
D=4
E=5
F=6
G=7
H=8
I=9
J=10
K=11
L=12
M=13
N=14
O=15
P=16
Q=17
R=18
S=19
T=20
U=21
V=22
W=23
X=24
Y=25
Z=26
God = 27 ( 9 + 9 + 9)
JHVH = 48 (6 x Cool - (3 x (16*) ) *Fadic = 1+6 = 7
JHWH = 49 (7 x 7)*
&Because it is exactly 7^2, I suggest that this is the true correction of God’s name/Tertragrammaton.
Love = 64
Hate = 34
Water = 67
Tear = 44
Tear of God = 92
Wrath of God = 138
God of Love = 112 – (JHVH_ In Hebrew calculus) AND /7 = 16 fadic of 7
Spirit of God = 130 > 7th prime x 10
Spirit = 82
Of = 21 (7 + 7 + 7)
And = 19 (7th prime)
The = 33
He = 13
Will = 56
Power = 77 (7 x 11)
Wrath = 70
System = 101
Satan = 55
Devil = 52
Man = 33
Human = 57
Sin= 42 (6 x 7) – we all have both good and evil….
Number = 73
Number of Man = 127
Number of Beast = 141
False Prophet = 141
Using The Above, I have designed my own following scripture:::
‘’1.‘God’ will find his people in great ‘sin’ (a)(b). 2. ‘He will return’ on the ‘third day’, and the ‘God of Wrath’ will show that He is The ‘God of Love’ for his people(c)(d). 3. His people have the ‘Number of Beast’, which is also the same as the number of the ‘False Prophet’. (e)(f) ‘’
(a) = 19 con. = 7th prime
(b) = 11 vow. = 1 x 11
19 + 11 = 30- (The) and (Wrath x 3)
His People is ‘’MAN’’ = (33- (11 x 3) )
(c) = 53 con. = 11th prime
(d) = 28 vow. = 7 + 7 +7
False prophet = 141
53 + 28 = (81- (9 + 9 + 9) )
Which is the same as the following:
‘’ God = 27 (9 + 9 + 9)’’
(e) = 46 con. = 2 x 23rd prime
(f) = 29 vow. = 23rd Prime
If anyone follows this correctly, it means that language is a mathematical design. There can be only so many probabilities to how this could have been done.
1. That the ‘’first’’ men or man spoke in math rather than tongue – or both.
2. That Hebrew was the very first language devised, and man was inspired by God.
Take your pick, because either way it shows that the Bible Codes, whether they be of the Ancient Hebrew, Greek, Latin or modern English, proves that they are indeed something of an intelligent design which could be one of the three following:
1. That God Inspired Man
2. That Man Inspired Himself (which is highly UNLIKELY)
3. Or that Aliens gave this knowledge to us, over 3500 years ago… Which is probably MORE LIKELY THAN choice 2, but not of choice 1.
Summery: To devise such a compilation, and complex structure, one would need to write the Bible back-to-front, so that no mistakes where made. The statistics of this goes into 1 in quadrillions!!!!!
Guest
Guest
PostSubject: Re: Bible Codes   Sun Jun 06, 2010 3:54 am
........1(a)
.......18
......183
.....1836
....18365
...183654
..1836547
.18365472
183654729
Call (a) ''central one,'' - now, if you rotate the same pattern into a maltese cross so the ''central one'' makes ''A CROSS'', All the numbers calculate to Exactly (777) - the importance of this number has been shown by my following work presented first by Dr Jenkins and Panin:
''Now, what stood out for me, was that seven was predominant in the first sentence. There are accordingly 7 words. There are 28 letters (Hebrew letters) which is of course 7 x 4. This was indicating something, i thought.
37 x 7 = 259
39 x 7 = 273
And…
77 x 7 x 13 = 7007
7007 x 39 = 273273
7007 x 37 = 259259
Right, so i make it that the possibility of chance to be 1 in 108,775,477,775.''
Guest
Guest
PostSubject: Re: Bible Codes   Mon Jun 07, 2010 7:31 am
I thought Brennus, you would have seen something in it to question?
I am... bewitched by the reason why no reply to this has happened, has abandoned my hope any may have understood it's implications...?
Maybe if i explained it in just a few paragraphs...?
Guest
Guest
PostSubject: Re: Bible Codes   Mon Jun 07, 2010 7:47 am
So, up to my calculation of 3773(37 x 13 x 39)= 70777707.
Right, so i made it that the possibility of chance to be 1 in 108,775,477,775 using statistics. These statistics have focused on the first seven words of the Bible… The beginning of everything, maybe even God Himself.
It is true that 1 in 108,775,477,775 is a very large statistic. But the true chances for instance for a vacuum to come into existence is 10^10^100, which is by tens of hundreds greater than the value greater than the original statistic made of the Bible Code.
But which statistic is the true statistic of the world?
The one we created, or the one God created…?
The questions might seem easy... but there can be more than one answer for all of them, which is what troubles me.
Guest
Guest
PostSubject: Re: Bible Codes   Mon Jun 07, 2010 1:08 pm
No takers Sad
Guest
Guest
PostSubject: Re: Bible Codes   Mon Jun 07, 2010 1:09 pm
There is a lot here, give us lesser beings a little time to work on it, Also life sometimes interferes with computer time.
Guest
Guest
PostSubject: Re: Bible Codes   Mon Jun 07, 2010 1:13 pm
Sorry.
I feel like i am in a world of Tempus Fugitism.
Guest
Guest
PostSubject: Re: Bible Codes   Mon Jun 07, 2010 1:17 pm
You have had all the time that you researched developed and wrote it, the rest of us are coming in cold. be patient.
Guest
Guest
PostSubject: Re: Bible Codes   Mon Jun 07, 2010 1:19 pm
Yes, it's a virtue many have...
imp-pulse
PostSubject: Re: Bible Codes   Mon Jun 07, 2010 1:25 pm
where are the palindromes? lost in translation?
Guest
Guest
PostSubject: Re: Bible Codes   Mon Jun 07, 2010 1:27 pm
A palindrome is something which can be spelled forward equally as it can backwards.
A number like 777 can be read forward, and thus 777 is still the same representation when read back the way. This is what defines a mathematical palindrome.
imp-pulse
PostSubject: Re: Bible Codes   Mon Jun 07, 2010 1:35 pm
maths is not the everyday language of humans.
my computer compatibility may not even have begun its doubtful evolution yet.
Guest
Guest
PostSubject: Re: Bible Codes   Mon Jun 07, 2010 1:55 pm
Palindromes also exist in language.
'Madam I'm Adam' is a familiar one it reads the same forwards as backwards.
Guest
Guest
PostSubject: Re: Bible Codes   Mon Jun 07, 2010 2:14 pm
Yup.
imp-pulse
PostSubject: Re: Bible Codes   Mon Jun 07, 2010 2:23 pm
http://en.wiktionary.org/wiki/Appendix:Palindromic_words#15_letters
were all frequencies already measured as impacting on dna even before the "invention" of maths as an evolutionary science tool kit?
there's an omni-bus just passing by my window.
Guest
Guest
PostSubject: Re: Bible Codes   Mon Jun 07, 2010 2:27 pm
I've applied a toll to this. If the math is hard to understand, then just look at the patterns and try and make a choice, if you will to participate in what caused such a strange occurrance?
Nyarlathotep
PostSubject: Re: Bible Codes   Tue Jun 08, 2010 7:31 pm
Bible Code = Qabala for people who don't know what they're talking about
http://rocktownrebel.wordpress.com
Guest
Guest
PostSubject: Re: Bible Codes   Wed Jun 09, 2010 3:21 am
They are pretty much defining the same definition of a goal... and that is define a God.
Bible Codes
Page 1 of 1
 Similar topics
» Asetian Bible
» The Book of Doom (The Unholy Bible) and other digimob files
» The Incredible Bible Codes- by Lee Martone
» Bible Codes
» Kabbalah and the Bible Code
Permissions in this forum:You cannot reply to topics in this forum
Dissident Philosophy Forum :: Salon-
